It is currently Thu Jul 17, 2025 12:44 am
PostPosted: Sun Nov 05, 2017 8:58 am
Resident Haemorrhoid
Hello all,
My 72 clubman is playing games in starting
Some days she will start first go other days she will refuse and require aerostat to get her going
Fuel seems ok
Spark seems low ( how can I check this apart from visually)
It is running a pulsar dizzy
Could the module be knackered?? Once again how can I check this
Timing appears correct
New coil fitted and leads n plugs
Once it starts n warms up runs fine
Help please
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Nov 05, 2017 10:02 am
Choke working properly ? :idea:
Has it only just started doing this? ,What was it like in the cooler months?
PostPosted: Sun Nov 05, 2017 10:08 am
Yeah choke works properly
On colder days sometimes choke reqd and similar temps on other days starts first go without choke it's so hit n miss that has me wondering if the electronic module in the dizzy is the culprit
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Nov 05, 2017 10:54 am
try using the choke every time and see if it's different - even if you don't think it'll need the choke, use it
PostPosted: Sun Nov 05, 2017 10:57 am
Okay will give it a go
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Nov 05, 2017 11:47 am
Properly tuned SUs will always need choke to start from cold.....
Cheers, Ian
PostPosted: Sun Nov 05, 2017 1:29 pm
Pulsar dizzy modules are very reliable. Either they work fine, or die totally (uncommon) unless you hooked it up wrong.
I had twin HS4s on Barney's 1293 and it was always a bugger to start when cold, even with full choke.
PostPosted: Mon Nov 06, 2017 10:46 am
Help please
Go back and check the latest thing changed Sime...replacement parts, these here days, vary in quality...there is also the problem of Maintenance Induced Faults...so go over the ignition again looking for loosey-loosey, burning, cracked etc :D
PostPosted: Fri Nov 10, 2017 8:32 pm
Is your starter drawing too much Current on cranking not leaving enough Volts to fire up the ignition? Many people overlook this fact.
"Let us remove your "SHORTS"
PostPosted: Wed Nov 15, 2017 7:44 pm
I have a 1977 Clubman that was a bugger to start cold. Excessive cranking, full choke, no choke, no throttle, full throttle - it was hit and miss. Some days would start easy other days not. Fitted a Bosch GT40R coil and ballast resistor, now starts like a new car - every time.
I also have an old Nissan ute that's is difficult to start (only starts when releasing key from the "cranking" position) Found that when cranking the ignition system would drop out till the key was released from cranking. Found it to be a defective ignition switch. Found by "lightly" turning the key to crank would start every time.
Hope this is any help.
Cheers Dave
PostPosted: Sun Nov 19, 2017 3:42 pm
i was about to suggest to check exactly this Dave,,, very common proplem these days
easy to check too
