three questions 1970 CS https://ausmini.com/forums/viewtopic.php?f=2&t=96260 |
Author: | p7676 [ Thu Nov 02, 2017 4:42 pm ] |
Post subject: | three questions 1970 CS |
I have had the master cylinders reconditioned plastic tank type does it matter which is the clutch and which is the brake MCs?. Also there is a plate under the brake MC is this ok ? What is the best way to fit the pedals ? fit bracket then pedals or fit pedals to bracket then install. Thanks P7676 |
Author: | simon k [ Thu Nov 02, 2017 9:21 pm ] |
Post subject: | Re: three questions 1970 CS |
p7676 wrote: fit pedals to bracket then install.
Author: | gtogreen1969 [ Thu Nov 02, 2017 9:58 pm ] |
Brake is different internally as it has a one way valve. Use a 0.7" Brake as you need less pedal effort than a 0.75" (more pressure with the same effort) Use a 0.75" Clutch as it moves more fluid than a 0.7" |
