It is currently Sat Jul 19, 2025 2:29 am
 Post subject: three questions 1970 CS
PostPosted: Thu Nov 02, 2017 4:42 pm
I have had the master cylinders reconditioned plastic tank type does it matter which is the clutch and which is the brake MCs?. Also there is a plate under the brake MC is this ok ?
What is the best way to fit the pedals ? fit bracket then pedals or fit pedals to bracket then install.
Thanks P7676
PostPosted: Thu Nov 02, 2017 9:21 pm
PostPosted: Thu Nov 02, 2017 9:58 pm
Brake is different internally as it has a one way valve.
Use a 0.7" Brake as you need less pedal effort than a 0.75" (more pressure with the same effort)
Use a 0.75" Clutch as it moves more fluid than a 0.7"
