https://ausmini.com/forums/
Rear Mini Wiring Loom
https://ausmini.com/forums/viewtopic.php?f=2&t=96259
Author:  cooperess [ Thu Nov 02, 2017 2:50 pm ]
Post subject:  Rear Mini Wiring Loom
Whilst pulling my Cooper apart I found AYA9196 on the rear wiring loom.
When was this loom used (from date to finish date) and what models?
Author:  cooperess [ Thu Nov 02, 2017 3:07 pm ]
Post subject:  Re: Rear Mini Wiring Loom
Here is a Picture
Author:  winabbey [ Thu Nov 02, 2017 4:39 pm ]
Looks like that body harness was used for the MK II Mini series beginning in 1969. No information on whether it was superceded before the end of round-nose production but I suspect not. Reversing lights weren't introduced until the Clubman series, except the SPO41 harness to enable reversing lights.
On the following page, S is for Saloon and V for Van.
Author:  winabbey [ Thu Nov 02, 2017 4:44 pm ]
The parts books show that loom as also being used in the early non-GT Clubman production.
Author:  cooperess [ Sat Nov 11, 2017 8:52 am ]
Thanks winabbey.
Do you have the illustrations referred to on the picture, if so, I am interested in seeing the Item illustration No.s 1B & 2D
Author:  Mick [ Sat Nov 11, 2017 9:28 am ]
There is a difference between the Mini K rear wiring loom and the Cooper S, in that there is a need for a switched 12 volt wire to run to the rear mounted electric fuel pump. This is a white wire running in the middle pin if I remember correctly. Otherwise it is left empty.
Author:  winabbey [ Sat Nov 11, 2017 10:56 am ]
cooperess wrote:
Thanks winabbey.
The illustration page in the parts book just shows the routing of the harnesses, not the cable lengths, wiring colours and terminations that I suspect you are wanting? This information is in the workshop manual. Below are the relevant pages from the most comprehensive BMC produced workshop manual, TP832, the black covered publication.
I have a feeling the same loom was used but the fuel pump wire just taped up out of the way on the Mini K. I wonder if a Mini K owner could check their car and report back?
Author:  Mick [ Sat Nov 11, 2017 11:11 am ]
The Mini K looms I have had had the center wire not fitted, but certainly may not be across the board. I would suppose they would share a part number if they were used on either model?
Author:  Stibbsy [ Sat Nov 11, 2017 12:22 pm ]
The rear wiring loom on my '69 Mk2 'S' has a white wire
Author:  simon k [ Sat Nov 11, 2017 12:56 pm ]
which pin does it go to?
cooperess' loom appears to have a white wire, but doesn't go to the centre
Author:  Stibbsy [ Sat Nov 11, 2017 1:28 pm ]
Simon,
The white wire is on the ribbed edge of the block in the middle between purple wire and green with red trace. It's defineatly for the fuel pump.
Author:  drmini in aust [ Sat Nov 11, 2017 2:48 pm ]
My 70 Matic has no white wire, the pin is vacant. Ditto the loom in my son's 71 Clubby.
Author:  Tim I [ Thu Dec 07, 2017 11:20 pm ]
Doug,
Our Mini K is fairly early - YG2S1 776 - and has no white wire in the rear harness.
Author:  winabbey [ Fri Dec 08, 2017 5:59 am ]
Tim I wrote:
Doug,
Ah OK, thanks. So the Cooper S had a different rear harness to the other models without electric pump. All adds to the knowledge base.
