It is currently Mon Jul 21, 2025 5:24 am
 Post subject: Spark plug adjustment
PostPosted: Sun Dec 03, 2017 6:07 pm
Hi all
Do I need to adjust the gaps on my plugs when installing electronic ignition kit + upgraded ignition coil?
Thanks
Eiles
PostPosted: Sun Dec 03, 2017 6:30 pm
You can easily go out to 30thou from the std 25thou
PostPosted: Sun Dec 03, 2017 6:35 pm
PostPosted: Tue Dec 05, 2017 7:53 am
If you're going for maximum gap, don't forget to index them.
PostPosted: Thu Dec 07, 2017 9:35 pm
How do i go about doing that?
PostPosted: Fri Dec 08, 2017 6:14 am
You put shims under each plug so the electrodes all point the same in the chamber. It's a V8 thing, not sure it makes a difference in an A series with siamesed ports.
PostPosted: Fri Dec 08, 2017 8:17 pm
Thanks for info dr.
Never knew such a thing existed.
