Cooper S Mk2 Reverse Light https://ausmini.com/forums/viewtopic.php?f=2&t=96237 |
Page 1 of 2 |
Author: | cooperess [ Sat Oct 28, 2017 7:11 am ] |
Post subject: | Cooper S Mk2 Reverse Light |
I was looking at Australian Production Mini TP 759 A Electrical System diagram and saw there was reversing lights. Does anyone know when the Cooper S starting using reverse lights? |
Author: | winabbey [ Sat Oct 28, 2017 11:32 am ] |
Post subject: | Re: Cooper S Mk2 Reverse Light |
cooperess wrote: I was looking at Australian Production Mini TP 759 A Electrical System diagram and saw there was reversing lights. Does anyone know when the Cooper S starting using reverse lights? The wiring diagram in the later Australian produced workshop manual says reversing lights is an option, not standard on the Cooper S. The first, and I believe only use on round-nose Minis was on the cars supplied to NSW Police. Other than that they weren't used until ADR 1 mandated them on all vehicles from January 1972. https://infrastructure.gov.au/roads/mot ... _adrs.aspx They were introduced into production on the Clubman range with change points as detailed in this Parts Amendment Advice. Attachment: PAA 75 p08.jpg
Author: | GundyGuy [ Sat Oct 28, 2017 12:18 pm ] |
My 3/1970 Cooper S has the switch fitted to the gearbox but i cant find the wiring for it The wiring looks a bit fiddled with only as in someone has re-taped it and maybe the wires are hidden |
Author: | gtogreen1969 [ Sat Oct 28, 2017 12:26 pm ] |
GundyGuy wrote: My 3/1970 Cooper S has the switch fitted to the gearbox but i cant find the wiring for it The wiring looks a bit fiddled with only as in someone has re-taped it and maybe the wires are hidden Do your tail lights have the reverse light mod? |
Author: | winabbey [ Sat Oct 28, 2017 12:36 pm ] |
GundyGuy wrote: My 3/1970 Cooper S has the switch fitted to the gearbox but i cant find the wiring for it The wiring looks a bit fiddled with only as in someone has re-taped it and maybe the wires are hidden The factory loom will have a green wire from the switch to the fuse block A4 and a light green with brown trace from the switch to the body junction (joining main and rear looms), then the same back to the rear lights. As gtogreen1969 has suggested, check whether your rear lamps (two screw AL136) have twin-filament bulb holders instead of single-filament in the turn indicator position. |
Author: | GundyGuy [ Sat Oct 28, 2017 4:32 pm ] |
I will have a look |
Author: | 69Cool [ Sat Oct 28, 2017 4:37 pm ] |
Does this mean all the 1969 police cars had reversing lights? |
Author: | winabbey [ Sat Oct 28, 2017 4:53 pm ] |
69Cool wrote: Does this mean all the 1969 police cars had reversing lights? The reverse light Special Production Order (SPO25) was specified for all NSW Police Cooper S's, but possibly also applied to sedans and vans used by Police as station cars and escort vehicles, so in theory the answer is yes. SPO16 Lowered Front Seats applied to all Minis, and SPO26 Racing Disk Pads only to the Cooper S, naturally. |
Author: | 69Cool [ Sat Oct 28, 2017 5:09 pm ] |
I had work done to my brakes a few years back & found out they were a police special order. The car has a racing cam but only the 11/4 SUs. No reverse lights. Do the seats have a number on them? |
Author: | winabbey [ Sat Oct 28, 2017 5:44 pm ] |
Up to Sept 1970 all S's supplied to NSW Police were stock standard, except for the three SPO's I mentioned above. No numbers on the seats, just the visible weld. Your brake mechanic was having you on regarding special brakes. They were absolutely stock standard Cooper S. |
Author: | timmy201 [ Sat Oct 28, 2017 5:57 pm ] |
Although the SPO41 cars had different brake pads to the stock cars? Those would be long gone by now though! viewtopic.php?p=993831#p993831 Another good post by winabbey about reversing lights here viewtopic.php?f=2&t=91761&p=1018723&hilit=spo41#p1018723 |
Author: | 69Cool [ Sat Oct 28, 2017 6:38 pm ] |
It was actually the brake booster. The story goes like this ![]() |
Author: | gtogreen1969 [ Sat Oct 28, 2017 6:49 pm ] |
69Cool wrote: It was actually the brake booster. The story goes like this What is the serial number on the booster? Originally your car would have had the same booster as all the MK1 S cars not the PBR one currently fitted. The Mk2 S used the "Lockheed 5 1/2" from car 501 to 1613. The "PBR VH44-J" started at car 1614 in March 1970. I am not aware of any other boosters used. Nothing detailed in the SPO's either.![]() Sounds like they put a different booster on during the rebuild. Maybe a different VH44 because they couldn't find a J. Sorry for the thread hijack |
Author: | 69Cool [ Sat Oct 28, 2017 7:03 pm ] |
I will have a look to see if I can find it. Unfortunately, I have moved & lost a few boxes of important literature including my Mini file |
Author: | gtogreen1969 [ Sat Oct 28, 2017 7:10 pm ] |
69Cool wrote: I will have a look to see if I can find it. Unfortunately, I have moved & lost a few boxes of important literature including my Mini file The serial number was on a label, probably long gone now. |
