It is currently Sat Jul 12, 2025 1:28 pm
PostPosted: Fri Oct 27, 2017 12:44 pm
I have the above pump and was wondering if there was a kit available to bring it back from the dead.
PostPosted: Fri Oct 27, 2017 1:57 pm
Wow, that's one of the very early pumps with the C clip locating the bearing. I'm not aware of a source of parts to refurbish it but I recently got a restored cast iron pump with cast impeller for my MK II S from MKO. John Smidt has someone who overhauls these for him. He may be able to help so suggest you give him a call (0427 671 314) if you don't have luck elsewhere.
https://minikingdomonline.com.au/produc ... nditioned/
PostPosted: Mon Mar 04, 2019 5:55 pm
I have tracked down some original water pump rebuild parts just got to find the bearing if anyone knows where to get them or the part number please let me know.
PostPosted: Mon Mar 04, 2019 7:53 pm
I found a bearing on eBay. I got it from MG Spares.
PostPosted: Sat Mar 09, 2019 10:28 pm
Bit late, but parts book shows the spindle & bearing come as one unit 12A1389.
PostPosted: Sun Mar 10, 2019 7:10 am
That's the part I'm after, spindle and bearing. Does any one have the dimensions?
PostPosted: Sun Mar 10, 2019 10:20 am
Larry,
I believe a mate of mine in the ACT recently overhauled a cast iron pump for his S. He is a stickler for originality (none of this alloy crap!).
I will ask him what he did regarding the spindle & bearing. He is a machinist so maybe he made his own. He designed & made his own spot welder so he is no fool. I am guessing the bearing is a generic item and can readily be found.
May take a few days as I only see him a Club meetings.
PostPosted: Sun Mar 10, 2019 10:39 am
Thanks Pete.
PostPosted: Tue Mar 12, 2019 7:49 am
I have tracked down a source for original water pump repair kit.
Depending on interest from forum members I can get a kit for $150 posted.
Please PM me if you are definitely interested.
