It is currently Fri Jul 18, 2025 10:49 am
 Post subject: Starter Motor
PostPosted: Wed Oct 25, 2017 10:21 am
Gday. What's the latest with Starter Motors? I've had it with the original type and want to change to the pre-engaged Gemini type.
After some searching on here I ordered one from MG Spare Parts (Heritage MG) but got a message back that they are out of stock.
Am I best to get an original Gemini one to modify from a wrecker, or are the new ones better? I see Minisport stock one but quite pricey at $450. I guess anything original from a Gemini is quite old now for an electric motor..
'69 Mini 1100 (base model Mini K), '54 Land Rover (Series 1), '69 VW Beetle, '85 Land Rover 110 County.
 Post subject: Re: Starter Motor
PostPosted: Wed Oct 25, 2017 10:25 am
You can get new Gemini starters on eBay for around $170 last time I looked.
To make them fit takes 10mins to file the mounting flange holes.
You will need to either keep the old Lucas solenoid to drive the Gemini one, or ose a 40A relay. Otherwise your ignition switch will get to handle 35A. Not designed for this.
PostPosted: Thu Oct 26, 2017 10:13 am
Many thanks. I'll track down a new Gemini one. The mods and electrical shouldn't be a problem, thanks for the tips. Cheers.
PostPosted: Fri Oct 27, 2017 4:56 am
You could check with Tony , Mini Convertable on here , i'm sure he has them .
PostPosted: Fri Oct 27, 2017 10:56 am
Does it have to suit a certain model?
Sent from my HTC_PN071 using Tapatalk
PostPosted: Fri Oct 27, 2017 8:59 pm
Like this
https://www.ebay.com.au/itm/Holden-Isuz ... 0011.m1850
Won't fit with an S oil cooler.
(Edit) unless you move it towards radiator.
Last edited by drmini in aust on Tue Nov 07, 2017 6:07 am, edited 1 time in total.
PostPosted: Fri Nov 03, 2017 8:53 am
Thanks for the replies. A Gemini one from Ebay is on it's way to me as we speak. Cheers!
PostPosted: Mon Nov 06, 2017 7:53 am
Have a Gemini one on my a+ but they don't crank as hard as the originals. Called Holden in the 90's and checked the cranking torque, turns out it's a little less then the Lucas original.
PostPosted: Mon Nov 06, 2017 8:23 am
And they draw a lot more current, 350A according to the data sheet.
But benefits are the pinion doesn't throw out if motor gives isolated kicks, also it doesn't munch the ring gear teeth up.
PostPosted: Mon Nov 06, 2017 8:11 pm
I use the ones from Tony, Convertible Mini.
Do a good job, and fit with the standard S oil cooler.
PostPosted: Mon Nov 06, 2017 10:26 pm
I have one of these too. It does the business no issues and has done for years.
PostPosted: Tue Nov 07, 2017 4:49 pm
I just cut the protruding nose off the flywheel "wok" so the pinion/bendix hangs in fresh air. Easy to get to, clean and keep lubricated with graphite. Never had a problem since.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Fri Nov 10, 2017 8:27 pm
I still make the Bosch Planetary geared Starters for Minis.Sold quite a few over the years. Most Australian Mini racers have one of mine fitted too. They are guaranteed to start any mini engine regardless of compression ratio or bore size. yes and they even fit on a cooper S with oil cooler in front. My own design modification that I am proud of.
"Let us remove your "SHORTS"
