https://ausmini.com/forums/
Please Delete Double Post
https://ausmini.com/forums/viewtopic.php?f=2&t=96205
Author:  gtogreen1969 [ Mon Oct 23, 2017 3:28 pm ]
Post subject:  Re: 1973 Clubman GT Distributor
GuamMini wrote:
What model number is the original distributor on a 1973 Clubman GT. is it the 29D is it a vacuum advance unit? Thanks
Should be a 29D Non vac advance with the stampings AYG0175. Well thats what the 1971 and 1972 cars had.
Author:  gtogreen1969 [ Mon Oct 23, 2017 3:48 pm ]
43D would be the replacement dissy for the 29D non vacuum dissy. The advance curve and total advance would be different to the original Cooper S/ GT but in my opinion probably better.
Here is the curve for the accuspark unit.
These are the readings of the original Cooper S / GT dissy.
Engine RPM / Crankshaft advance
650 rpm / 0 - 2 deg
830 rpm / 4 - 8 deg
1000 rpm / 8 - 12 deg
4000 rpm / 18 - 22 deg
7000 rpm / 28 - 32 deg
Author:  drmini in aust [ Tue Oct 24, 2017 2:51 pm ]
43D are common. Same as a 45D but the vac advance mount is covered. People call them 45D but they are stamped 43D.
Used on all the 1975 on 998 rodchange Mini and Moke here.
Author:  s-c1293 [ Wed Oct 25, 2017 4:53 am ]
Hi GuamMini, I have a 29D AYG0175 out of a MKII Cooper S if you are interested. PM sent.
Author:  1071 S [ Thu Oct 26, 2017 8:56 pm ]
GuamMini wrote:
Police cars had the stamping AYG0272.
Thanks do you know what centrifugal unit would be a good replacement from the British made distributors? I don't think I can find a centrifugal advance 29D. The one in my car has a vacuum advance unit.
All distributors (except those adapted to electronic control units) have centrifugal advance.
What's wrong with the one you have?
Cheers, Ian
Author:  1071 S [ Fri Oct 27, 2017 9:38 pm ]
Unless you have some strong desire for “originality” a vacumm advance is a VERY good thing to have..
Depending on how and where you drive you might expect fuel savings of up to 30%.....
Cheers, Ian'
