It is currently Fri Jul 18, 2025 11:20 pm
PostPosted: Tue Jan 04, 2005 9:36 pm
What's the worst job you have had to do on a Mini?
I reckon I found mine today........fitting all the internals into a door.... :evil: Spent hours today fitting the 1/4 vent window, sliding glass, window winder, door lock and barrel....etc..... Just finished one door tonight and the lock doesn't work!! :shock: Looks like I have to remove the lock mechanism tomorrow..... :evil: :evil:
BUGGA!
PostPosted: Tue Jan 04, 2005 9:38 pm
ha ha... try working out how the hell to get the handle off the older version... where you cant just unscrew the damn thing when the lock is busted... :evil:
There is always that rooflining thing...
PostPosted: Tue Jan 04, 2005 9:41 pm
I was thinking about putting this topic up as i struggled to get the u-bolts into the unviversal joints on Sunday. :evil: it helps to wind the hilos off and make the driveshaft more in line with the gearbox, and especially helps to have straight u-bolts that will actually go into the holes. a couple taps with the BFH cured that, but i still needed three hands to lift driveshaft, slide the joint together, line up the rubber, and slot the u-bolt in :roll:
PostPosted: Tue Jan 04, 2005 9:44 pm
[quote="IwannaMini"]ha ha... try working out how the hell to get the handle off the older version... where you cant just unscrew the damn thing when the lock is busted... :evil:
quote]
fixed that one when i had to get into the car when i forgot the keys at the supersprint :oops: broke lock, swapped handles with passenger side so it would pass scrutineering, then it came out somewher on track :)
PostPosted: Tue Jan 04, 2005 10:02 pm
I still say the Radiator out special when the P/O has put the bottom hose clamp around the wrong way :twisted:
Some may say the Rack and pinion :?:
PostPosted: Tue Jan 04, 2005 10:04 pm
BUGGA!
And I told you it would take a weekend to do 2 doors properly, wasn't far out was I. :lol:
I think the worst thing is that bloody circlip on the Deluxe/S outer door handle. But I found you can do without it if you pre-bend the c-channel thingy out a bit. :P
Last edited by drmini in aust on Tue Jan 04, 2005 10:06 pm, edited 1 time in total.
PostPosted: Tue Jan 04, 2005 10:06 pm
no wonder BMC and Leyland went bust. 2 days to assemble a door :shock:
PostPosted: Tue Jan 04, 2005 10:09 pm
Love it mick.
Yeah leyland really ****ed up with the locks and handles. The pins on them are all starting to fatigue and break now have u noticed. I've done my passenger one a month ago and i keep having to push one of the pins back in on the drivers side.
PostPosted: Tue Jan 04, 2005 10:12 pm
lucky both mine have slidey windows. much easy
PostPosted: Tue Jan 04, 2005 10:32 pm
And I told you it would take a weekend to do 2 doors properly....
indeed you did....BUT....you failed to mention the fact that I might scratch the hell out of the door uprights..... :shock: .....lucky I am a pro at touching up..... :lol:
PostPosted: Tue Jan 04, 2005 10:49 pm
I'll leave that one alone about touching up J_A_M :shock:
Hmmmm, that little bypass hose can be a bugger, undoing the speedo drive at the block, bottom radiator shroud ....man it just goes on and on :cry:
PostPosted: Tue Jan 04, 2005 10:55 pm
9YaTaH wrote:
I'll that one alone about touching up J_A_M
:lol: Dirty boy....I had to think hard about that one...... :?
PostPosted: Tue Jan 04, 2005 11:09 pm
the only thing that has gotten me
is replacing the traingular rubber in the triangular window.
its the only thing that has gotten me so i went to sleep
Inconspicuously Conspicuous
PostPosted: Tue Jan 04, 2005 11:12 pm
Antons a expet now :lol: Sorry Mate
PostPosted: Tue Jan 04, 2005 11:19 pm
hmmm ive got a new best friend... his name is anton
Users browsing this forum: No registered users and 116 guests
