It is currently Fri Jul 18, 2025 3:51 pm
 Post subject: LED globes
PostPosted: Sat Oct 21, 2017 2:33 pm
Daffodil 1275
Since night driving with the original globes is like candle light, I am considering updating the lighting. It wasn’t so much an issue until I moved into the country where Skippy & friends are hard to see !!! Is it as simple as a globe swap ? Or will fuses etc come into play?
Life advice
Don't wait for the storm to pass
Learn to dance in the rain
OR
Go drive your MINI
 Post subject: Re: LED globes
PostPosted: Sat Oct 21, 2017 2:58 pm
Some good quality H4 conversion lenses and a couple of relays will make a huge difference.
The H4 conversion is a simple bolt on swap, with some decent H4 globes you'll get much more light.
The relays will need a little bit of electrical wiring and then you can use higher wattage globes
PostPosted: Sat Oct 21, 2017 3:59 pm
Daffodil 1275
Thanks Timmy
Life advice
OR
Go drive your MINI
PostPosted: Sat Oct 21, 2017 4:46 pm
I’ve recently swapped to the wipac quadoptic kit. Haven’t had a good chance to use them at night but they look good
viewtopic.php?f=2&t=95696&hilit=Quadoptic
PostPosted: Sat Oct 21, 2017 6:25 pm
Why not fit a an LED light bar for night driving, there is no comparison ,they give a fantastic white light and easy to detach(2 bolts) for the original look
Edit : You will find it hard to go back to normal lights after using one of these
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sat Oct 21, 2017 8:04 pm
I'm really happy with the quad optics too except one got smashed, I replaced it with a normal H4 and can notice the difference.
Also really happy with these on Spot, bulbs are halogens that fit into the old lights:
I was going to put LEDs in the flood beams but the vintage globes guy advised me not to as the spread and distance wouldn't be as good. Probably differs if the optics are specifically designed for LEDs as with the light bars or LED headlamps.
Roads need more corners
PostPosted: Sun Oct 22, 2017 12:09 am
Daffodil 1275
Funnily enough I had the 4 spotties but took them off as it seemed a little overkill. I was living in a well lit area & never used them. Would just changing to the halogen make a reasonable difference?
Life advice
OR
Go drive your MINI
PostPosted: Sun Oct 22, 2017 5:19 am
Relays and the quad optics I reckon would help yes, it was only because I wanted to be better able to spot roos etc that I wanted the spots.
PostPosted: Sun Oct 22, 2017 5:37 pm
What modle is your mini? if its a square nose you could fit a LED bar behind the grill.
PostPosted: Sun Oct 22, 2017 7:56 pm
Daffodil 1275
1969 Mini Cooper S Mk 2
Life advice
OR
Go drive your MINI
PostPosted: Mon Oct 23, 2017 8:40 am
Wiring the standard sealed beams with relays makes a pretty significant difference, worth a try doing that first. If you convert the headlights to H4s they will need to be rewired anyway.
Sent from my ASUS_Z017DA using Tapatalk
PostPosted: Mon Oct 23, 2017 8:51 am
You shouldn't need to rewire the headlights for an H4 conversion?
PostPosted: Mon Oct 23, 2017 9:20 am
Unless you are putting 100W globes in maybe.
My Wipac Quadoptic 55/45w lights work fine with the original wires. I just fitted a New Era relay to avoid voltage drop in the switch wiring.
PostPosted: Mon Oct 23, 2017 12:33 pm
Plugs for the H4s are the same as sealed beams.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Mon Oct 23, 2017 12:54 pm
55/45 H4s work fine without relays. Same load as now.
But a relay takes under an hour to fit, gets more V to the lamps and saves your switchgear.
