Drive flange offsets- 7.5" to 8.4" https://ausmini.com/forums/viewtopic.php?f=2&t=96143 |
Author: | Harley [ Thu Oct 12, 2017 10:14 am ] |
Post subject: | Drive flange offsets- 7.5" to 8.4" |
Hopefully a quick one for those that know / have a flange of each to compare: Is the drive flange of an 8.4" brake setup the same in offset from bearing to wheel mounting face as it is on a 7.5" setup? Was looking at some photos recently and it looks different but i can't quite tell. Thanks! ![]() |
Author: | peterb [ Thu Oct 12, 2017 4:12 pm ] |
Post subject: | Re: Drive flange offsets- 7.5" to 8.4" |
they mount differently, one with the wheel studs, the other has own bolts.........if that makes sense |
Author: | Harley [ Thu Oct 12, 2017 8:38 pm ] |
Hi Peter, I'm trying to work out of changing from one setup to the other will alter the front track dimension? |
Author: | peterb [ Fri Oct 13, 2017 6:00 am ] |
I don't think it does, I swapped mine 8-7 and didn't notice any change. Didn't actually put tape over it but looking at tyre/guard position I'd say the same. |
