https://ausmini.com/forums/
Small alloy number plate
https://ausmini.com/forums/viewtopic.php?f=2&t=96136
Author:  ausdino [ Tue Oct 10, 2017 1:32 pm ]
Post subject:  Small alloy number plate
What is the significance of the number on the small alloy plate (secured by small machine screws) on the bonnet lock/support panel ? Both my mk2 S's have had them. On the first car 10/69 the number (62304) was also noted in the registration of ownership in the owners manual. I don't have the book for my current car. Doesn't match serial or engine number. An internal BMC build number ?? I did a search, couldn't find anything.
Author:  winabbey [ Tue Oct 10, 2017 1:36 pm ]
Post subject:  Re: Small alloy number plate
If it's like the one pictured below, they were installed by some dealerships as a simple way to identify each vehicle they sold for service or warranty work.
Author:  ausdino [ Tue Oct 10, 2017 2:23 pm ]
Thanks Doug, that's the one. So, not factory then ?? Do you fill the holes or put it back on ?? I realize that's a "how long is a piece of string" question.
Author:  winabbey [ Tue Oct 10, 2017 3:18 pm ]
I don't think either presence or absence of the plate will affect the car's value, so up to you. I would probably leave it, meaning the car is as sold originally.
Author:  ausdino [ Tue Oct 10, 2017 3:53 pm ]
Yep, thanks.
Author:  Phil 850 [ Tue Oct 10, 2017 5:47 pm ]
I have this plate on my 850.
Author:  winabbey [ Tue Oct 10, 2017 5:59 pm ]
Mine has this.
Author:  cgo [ Fri Nov 15, 2019 11:42 am ]
winabbey wrote:
Mine has this.
Doug,
I found a Larke Hoskins lubrication sticker in my collection of Mini things. It has MCS 1433 printed on it.
Do you know the significance of this number please?
Thanks
Author:  gtogreen1969 [ Fri Nov 15, 2019 12:45 pm ]
Dealers used an internal numbering system and would attach either a plate or later a sticker onto a car they sold. The MCS-xxx numbers were issued to the MK1 and MK2 Cooper S.
MCS 115 is a plate fitted YKG2S2 1712
MCS 1151 is a sticker fitted to YG2S4 1545.
MCS 1433 would probably be for a very late 1970 or early 1971 MK2 S.
UK Motors just used numbers for all cars. They started with large plates and ended up going to a small tag.
Author:  cgo [ Fri Nov 15, 2019 1:10 pm ]
Macka,
I believe it was attached car to YG2S4 2447.
Your resources are very impressive.
Thanks
Author:  gtogreen1969 [ Fri Nov 15, 2019 1:22 pm ]
cgo wrote:
Macka,
Thanks
You must have done well to get the sticker off without wrecking it.
Was the sticker originally located on the Flitch panel just forward of the Booster?
Author:  cgo [ Fri Nov 15, 2019 2:01 pm ]
Sticker was in a bag of bits, compliance plate, badges, etc, that came with the car. In poor condition, RH corner is damaged from being removed.
