It is currently Sat Jul 19, 2025 1:08 am
 Post subject: Resize image in Apple?
PostPosted: Sun Oct 08, 2017 10:14 am
Can anyone tell me how to resize images to post here using Apple?
PostPosted: Sun Oct 08, 2017 11:02 am
I presume you mean reduce the amount of memory used rather than cropping.
If Using a computer eg iMac or PowerBook . Select the image in iPhoto or photos. There is usually an option in the file or edit menu to "export", use this to select different options. Export to your desktop or a folder you create.
