PBR Brake Booster https://ausmini.com/forums/viewtopic.php?f=2&t=96119 |
Author: | cooperess [ Thu Oct 05, 2017 2:02 pm ] |
Post subject: | PBR Brake Booster |
This doesn't look right. Please advise what needs to be rectified. Attachment: Mini PBR Brake Booster 002.jpg
Author: | drmini in aust [ Thu Oct 05, 2017 2:10 pm ] |
Post subject: | Re: PBR Brake Booster |
The master cylinder bit needs to be flipped 180° on the servo canister if going into an S or roundnose. However if fitting it to a clubby it is better mounted pointing backwards, as assembled. |
Author: | Goldbrocade_62 [ Thu Oct 05, 2017 3:16 pm ] |
If you want to put in a 69mk2 S its incorrect should be the mk1 lockheed |
Author: | gtogreen1969 [ Thu Oct 05, 2017 3:31 pm ] |
Goldbrocade_62 wrote: If you want to put in a 69mk2 S its incorrect should be the mk1 lockheed Apparently changed at YG2S4 1614 in Mar 1970. Lots of cars with the wrong one.
Author: | Bubbacluby [ Thu Oct 05, 2017 7:13 pm ] |
Supposed to be gold and not silver and body isnt black |
