It is currently Sat Jul 19, 2025 12:59 am
 Post subject: Mini survival kit
PostPosted: Tue Oct 03, 2017 8:29 am
Hi All
I am after some advice as I edge closer to getting my mini on the road, what are must have's in my tool box in case of break downs or running repairs when I'm out and about?
I have a 1970 Mini K Van which is all standard and has the original 1098 engine.
Shifter, duct tape and a hammer?
The communities years of knowledge would be greatly appreciated.
 Post subject: Re: Mini survival kit
PostPosted: Tue Oct 03, 2017 9:16 am
Spose it depends on how far you're going to travel from home base and what back up you can call on. According to Murphys law the part/ tool you take with you will be the one you don't need. I personally just take the road service car, phone and phone charge lead.
PostPosted: Tue Oct 03, 2017 9:36 am
My car didn't have the original tools with it, so now most of the time I take a plastic tub with a few things, depending on the length of the trip:
Trolley jack
Wheel brace
Standard wheel nuts for the spare wheel
Cable ties
1L oil and water/coolant
Fan belt
And a couple of tools - screwdriver, pliers, shifter etc.
PostPosted: Tue Oct 03, 2017 1:24 pm
that's what I work on... I more-or-less take my whole toolbox when I'm going to do more than a couple of hundred k's
PostPosted: Tue Oct 03, 2017 1:38 pm
Trolley jack
Wheel brace
Cable ties
Fan belt
So many cars run after market wheels and a standard rim as a spare because a mag wheel won't fit in the boot. The "Standard wheel nuts for the spare wheel" is so important and often overlooked. Also check that the you carry a spanner that fits these nuts.
PostPosted: Tue Oct 03, 2017 3:37 pm
I carry a small plastic tool box into which I have crammed:
Small set of sidchrome sockets and bar,
Set of cheapo open end spanners, pliers, screwdrivers, spark plug socket, spare plugs, and a 4" shifter.
As well I carry a std Mini jack and winder/wheel nut spanner, and a 4 way wheelbrace for the mags.
One screwdriver is a long bugger to reach the bottom radiator hose.
Other spares: rad hoses, rad cap, thermostat and gaskets, fan belt.
PostPosted: Tue Oct 03, 2017 8:12 pm
Considering the vulnerable electrical system, apart from all of the above, I include spare points, condensor, these will get you home. Also fuel filter, test lamp, tow rope, rags, block of wood for the jack.
PostPosted: Tue Oct 03, 2017 9:19 pm
Rear radiator hose. I have blown 2 on different road trips (about 1000km from home), but both times had a spare with me. Had the required tools also.
Also blew a headgasket on a different road trip (800kms or so from home) and had brought a spare VRS kit with me (well atleast a head and manifold gasket). Again had the required tools with me to fix it.
PostPosted: Wed Oct 04, 2017 6:34 am
When I did the road trip to Bali I took a small box with:
condenser
rotor button
plugs
fanbelt
radiator hoses
spare front wheel bearing
spare electric fuel pump
oil filter
Basic tools, feeler gauges and multimeter (all fitted in an old toilet bag I had)
Think that was it.
Didn't use any of it. Didn't open the box, didn't even have a puncture....
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Oct 04, 2017 8:44 am
condenser
rotor button
plugs
fanbelt
radiator hoses
oil filter
Think that was it.
Because you took the box, its like an anti rain umbrella.
Nick
PostPosted: Wed Oct 04, 2017 11:37 am
oh, and a towel - always carry a towel, that way whenever you need to borrow something, you can say "I just need a <whatever>, I have everything else, look, I even have a towel, but my <whatever> is at home, can you believe it??!!"
PostPosted: Wed Oct 04, 2017 3:49 pm
Many thanks for all of your tips, being a van there is plenty of room for some spare parts so I will put your suggestions to work.
Hopefully I will need none of it but it's better to be a little prepared.
Thanks again.
