It is currently Sun Jul 20, 2025 10:23 am
 Post subject: Mk 2 Engine Numbers
PostPosted: Wed Sep 06, 2017 6:53 pm
Is it possible to have an engine number 9F/Xe/Y5****H
It's the 'H' that has thrown me, does anyone know what it means?
 Post subject: Re: Mk 2 Engine Numbers
PostPosted: Wed Sep 06, 2017 7:43 pm
Sometimes there are letters stamped on the end of engine numbers. Not sure why. I don't think they should be included in the engine number but.
I had a quick look through my photos and found 9 engines with either D, L, H, I, T or J. (Maybe a 7 or 1)
All are stamped on the right hand side of the rivet hole. Some upside down and they are on MK1 S and MK2 S engines.
PostPosted: Tue Oct 03, 2017 8:32 am
The 'H' on my engine number is to the right of the rivet hole.
Any other thoughts on what it means.
PostPosted: Tue Oct 03, 2017 6:29 pm
It probably doesn't mean anything officially , I have seen all sorts of numbers and letters stamped on the end of mini engine numbers .It was quite common practice (although illegal) Usually If they don't have a matching engine number some people just machine the block and re-stamp the number that is correct for the car , and add another letter or number to the end , just in case there is another vehicle registered with the original engine number :(
Edit : The exception is probably blocks with an 'S' on the end of the number , which apparently means the block was porous and was sleeved at the factory
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
Users browsing this forum: Scoop and 90 guests
