It is currently Sun Jul 13, 2025 9:27 am
PostPosted: Wed Sep 19, 2018 9:04 pm
Can anyone point me to where I may find a supply of 997cc pistons, both Mini Spares and Somerford no longer carry stock of the pistons only the rings.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
 Post subject: Re: Morris Cooper 997
PostPosted: Wed Sep 19, 2018 10:22 pm
moved to mini chat John... I think it's more of a "help please!" than a "wanted to buy"
PostPosted: Thu Sep 20, 2018 8:03 am
Is JP pistons still around they used to do them and many other classics
PostPosted: Thu Sep 20, 2018 8:19 am
Hi John , I do know a guy that has / had these , not sure if they are exactly what your after .
PostPosted: Thu Sep 20, 2018 8:32 am
Are 998 Cooper above.
I would bore it and fit 1098 ones. Then deck block a little to suit. Stroke isn't much less than 1098 is.
I bored a 997 block to 68mm years ago they are pretty thick walls.
Last edited by drmini in aust on Thu Sep 20, 2018 8:35 am, edited 1 time in total.
PostPosted: Thu Sep 20, 2018 8:34 am
Online
These are apparently NOS std size ones
https://www.ebay.co.uk/itm/Mini-Cooper- ... 2101157780
You can also try on this UK forum which focusses on early cars
http://mk1-forum.net
PostPosted: Thu Sep 20, 2018 8:37 am
https://www.norndaautomotive.com.au/
PostPosted: Thu Sep 20, 2018 8:47 am
https://www.norndaautomotive.com.au/jp- ... CR%209.4:1
PostPosted: Thu Sep 20, 2018 12:44 pm
Thank you for your responses - looks like I may be on the right path now.
Just measured the engine and to my delight the bore and crank are both still standard, may require clean up maching though.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
PostPosted: Thu Sep 20, 2018 3:22 pm
Crack test the 997 crank they are well known to crack. :wink:
At front or rear web.
PostPosted: Fri Sep 21, 2018 8:53 am
Hi John
I have sent you a PM
PostPosted: Fri Sep 21, 2018 4:30 pm
A little off topic but are original airfilter pancake type for coopers rare sought after etc ??
PostPosted: Fri Sep 21, 2018 4:50 pm
I think thery are remade in the uk
PostPosted: Fri Sep 21, 2018 5:54 pm
I thought the repro ones were not correct in the way they mounted... Might have a pair of originals here somewhere :P
Pairs of originals I have seen on UK ebay have generally sold for quite a bit...
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Fri Sep 21, 2018 6:40 pm
Mk1 sprite and cooper are almost the same one has captive nuts and one has bolts that go thru maybe the uk repro is sprite
