It is currently Fri Jul 18, 2025 8:56 am
 Post subject: Rust clearing
PostPosted: Thu Sep 21, 2017 12:50 pm
Hey all,
I recently bought myself a 1982 Leyland Mini. It's pretty decent condition, although still working on getting it to run. Currently, I am considering the best way to remove rust from the boot, considering it's essentially a big metal bucket and it has a fair amount of rust going for it. Can anyone recommend a few ways to best try to remove the rust?
Image album: https://imgur.com/a/9lRKL
Thanks,
BlackSirrah239
 Post subject: Re: Rust clearing
PostPosted: Thu Sep 21, 2017 2:58 pm
BlackSirrah239 wrote:
Hey all,
Thanks,
BlackSirrah239
That looks like surface rust only. Looks in great shape actually!
Zulu...
1967 mini Cooper S
PostPosted: Thu Sep 21, 2017 3:57 pm
Hey all,
Thanks,
BlackSirrah239
Do you reckon I should just buy some rust remover from the shops and give it a scrub?
PostPosted: Thu Sep 21, 2017 4:06 pm
It’d be a great place to start
Zulu...
1967 mini Cooper S
PostPosted: Thu Sep 21, 2017 4:26 pm
That doesn't look like a lot of serious rust.
I usually find the hardest way to do anything so consider any better suggestions, but I would use phosphoric acid watered down slightly, with a 3M scouring pad and rubbing over an area of the rust for 10 minutes or so. Keep the rust wet with the solution and finally wipe over with plain water. A wire brush on a drill can help dig out deeper rust. Apply another treatment until the metal looks clean.
Definitely wear rubber gloves.
The phosphoric acid is called by various names: the classic is Dulux Deoxidene, others have their own (usually cheaper) metal prep acid from auto paint suppliers, not hardwares.
There are also products that use phosphoric acid but they "treat" or coat the rust so that is made non-active, ready for painting.
I prefer the slow method.
PostPosted: Thu Sep 21, 2017 7:29 pm
wire brush on an angle grinder first, get all the paint and flaky stuff off - you'd get it back to shiny metal pretty quickly
PostPosted: Fri Sep 22, 2017 8:40 am
1982 Leyland mini? Didn't they finish in '78?
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri Sep 22, 2017 9:06 am
The rear window seems to be the wide UK size, which would suggest it could be an imported 82 model. The plate in the boot looks like an import compliance plate?
PostPosted: Fri Sep 22, 2017 9:09 am
Not saying its a good way, but I wonder how evoporust would go if you plugged the holes.
Nick
PostPosted: Fri Sep 22, 2017 4:33 pm
They had wider windows?
Zulu...
1967 mini Cooper S
PostPosted: Fri Sep 22, 2017 5:10 pm
Wider rear window, taller doors with internal hinges and windups etc.. The original rear window more or less lines up with the sides of the boot
Aus spec 1978
UK Spec - wider rear window, different boot handle, number plate recess and lamp
Edit: changed the first photo
PostPosted: Fri Sep 22, 2017 9:00 pm
That looks like the difference between a Mk1 and a Mk3
Zulu...
1967 mini Cooper S
PostPosted: Sun Sep 24, 2017 12:38 am
Plate in the boot looks like a Qld Mod plate. Date on it is 14/10/04, so it probably entered Australia sometime in 2004.
The mod codes on it are: LO1 - ADR Compliance, LK1 - Seat andSeat belts, and LK6 - Child restraint anchor points... all normal for a used import.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Mon Sep 25, 2017 2:46 pm
It was imported from Japan and registered in the ACT as a 1982 Leyland Mini. Good to see I sparked some conversation in regards to it's make though. I'm having extreme difficulties finding anything on the '82 Leyland minis.
I added an image of the ACT rego check for it that shows the Make/Model/Year to the previous album
