It is currently Sat Jul 19, 2025 3:56 pm
PostPosted: Wed Aug 30, 2017 1:17 pm
Hello - just got my mini back together and I get a squeaking at very low speed when the car coasts in neutral at very low speed - no sounds when in gear????
Any ideas
PostPosted: Sat Sep 02, 2017 9:51 am
When you say noise goes away 'in gear', is that just in a gear or is it with drive being applied? Like radiator cowl rubbing on body.
Is the noise in time with engine revs, wheel revolutions or with suspension movement - like a CV boot or clip rubbing or a dry suspension cup?
PostPosted: Sat Sep 02, 2017 12:49 pm
engine off, clutch in, gear selected, squeak?
PostPosted: Mon Sep 04, 2017 2:24 pm
Thanks for those suggestions - car is currently back for a final wet polish I will check out those suggestion when I get it back.
PostPosted: Tue Sep 05, 2017 1:15 pm
Wheels scrubbing on guard or inner wheel arch on rear?
PostPosted: Sat Sep 16, 2017 10:35 pm
Thanks again
Car back and I can confirm the noise disappears when the the gear is engagedand in drive . Definitely not wheels scrubbing on the bodywork and definetly from the front not the back ???
PostPosted: Sun Sep 17, 2017 6:50 pm
Is your car Auto or Manual?
PostPosted: Sun Sep 17, 2017 7:48 pm
Manual
PostPosted: Sun Sep 17, 2017 8:38 pm
Lucky bugger, I wish I ONLY had a front end squeak :?
PostPosted: Mon Sep 18, 2017 10:54 am
Again, is the squeak in time with the engine, wheel rotation, suspension movement or random?
PostPosted: Mon Sep 18, 2017 1:32 pm
Definetly in time with wheel rotation !
PostPosted: Mon Sep 18, 2017 8:06 pm
Tightened up the hub nuts to the next hole for the split pin and problem solved
Thanks for all the suggestions.
PostPosted: Tue Sep 19, 2017 10:26 am
So pleased you found the problem because that wasn't very high on my list of next suggestions.
PostPosted: Tue Sep 19, 2017 3:27 pm
Good...I would also make sure the hub is packed correctly with the right grease...if it can squeal with one castellation backed off...it may have also overheated a bearing...
PostPosted: Thu Sep 21, 2017 9:44 am
This
