CAM6232 Crank Shaft https://ausmini.com/forums/viewtopic.php?f=2&t=96061 |
Author: | cooperess [ Wed Sep 20, 2017 12:18 pm ] |
Post subject: | CAM6232 Crank Shaft |
I have the above crank shaft and wondering if it is OK to put in a MK2 Cooper S block and if so is there anything I need to know! |
Author: | drmini in aust [ Wed Sep 20, 2017 1:38 pm ] |
Post subject: | Re: CAM6232 Crank Shaft |
It's a big journal A+ crank, 1. your S rods won't fit unless you grind crankpins down from 1.750" to 1.625". And then machine the rods narrower. Alternatively, fit a set of A+ rods. 2. the standard 1275 thrust washers will be .032" loose, you will need to use +.030" ones and probably surface grind them to fit. Because a Cooper S block centre main web is 1/32" narrower than all other 1275 blocks. [edit] I have the opposite problem, an S crank in an 1100S block. I have to grind standard washers down. [edit 2] you can still buy EN40B S cranks new but they are not cheap... http://minispares.com/product/Classic/C-AEG479.aspx Some people find a good S/H early Morris 1100S small journal crank, they fit straight into an S block with thicker thrust washers same as I said above. |
