It is currently Sun Jul 20, 2025 12:42 am
 Post subject: CAM6232 Crank Shaft
PostPosted: Wed Sep 20, 2017 12:18 pm
I have the above crank shaft and wondering if it is OK to put in a MK2 Cooper S block and if so is there anything I need to know!
 Post subject: Re: CAM6232 Crank Shaft
PostPosted: Wed Sep 20, 2017 1:38 pm
It's a big journal A+ crank,
1. your S rods won't fit unless you grind crankpins down from 1.750" to 1.625". And then machine the rods narrower.
Alternatively, fit a set of A+ rods.
2. the standard 1275 thrust washers will be .032" loose, you will need to use +.030" ones and probably surface grind them to fit. Because a Cooper S block centre main web is 1/32" narrower than all other 1275 blocks.
[edit] I have the opposite problem, an S crank in an 1100S block. I have to grind standard washers down.
[edit 2] you can still buy EN40B S cranks new but they are not cheap...
http://minispares.com/product/Classic/C-AEG479.aspx
Some people find a good S/H early Morris 1100S small journal crank, they fit straight into an S block with thicker thrust washers same as I said above.
