Changing the windscreen wiper cable cooper s mk1 https://ausmini.com/forums/viewtopic.php?f=2&t=96057 |
Author: | 8700s14 [ Tue Sep 19, 2017 8:11 am ] |
Post subject: | Changing the windscreen wiper cable cooper s mk1 |
I have a quick question, should the cable that drivers the wiper wheel boxes just slide straight out of the wiper motor or is there something that holds it in place? |
Author: | Bill B [ Tue Sep 19, 2017 10:23 am ] |
Post subject: | Re: Changing the windscreen wiper cable cooper s mk1 |
If you remove the cover plate from the motor, you can see a flat bar (connecting rod) that joins the gear wheel to the end of the cable with a pin. The flat bar needs to be removed from the gear wheel to release the cable. An E clip and washer have to be "carefully" removed from the post on the gear wheel. Should be another washer under the flat bar same as on top. |
