It is currently Sat Jul 19, 2025 12:51 am
 Post subject: 1275 CRANKSHAFT
PostPosted: Fri Sep 15, 2017 5:37 pm
Is it advisable to attempt to remove a 0.005 inch bend ( indicated on the centre main bearing journal) of an EN40B Cooper S crank? Also needs grinding which will take it to 0.020 undersize. Has passed crack testing.Thank you.
 Post subject: Re: 1275 CRANKSHAFT
PostPosted: Fri Sep 15, 2017 8:19 pm
I had one of these which bent due to centre main bearing overheating. I was advised to not attempt straightening an EN40B crank but get it ground to the next undersize. It just cleaned up... ;)
PostPosted: Sat Sep 16, 2017 10:37 am
Yeahbut Doc...if it was bent wouldn't it still wobbulate :?:
I suppose decent bearings and a careful balance would minimise its effect...
PostPosted: Sat Sep 16, 2017 10:46 am
Check balance after grinding. No problemo.
Edit
If it's .005" total indicator reading it will clean up easily at the next undersize. .010" smaller.
Users browsing this forum: Bing [Bot] and 100 guests
