It is currently Sun Jul 06, 2025 1:55 am
 Post subject: Superfins - front?
PostPosted: Sun May 22, 2022 6:29 pm
My drums are a little worn and im not in the in market to replace the fronts with discs just yet.
I am considering Superfins all round - thoughts on this? are they worth the extra expense over standard cast drums?
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
 Post subject: Re: Superfins - front?
PostPosted: Mon May 23, 2022 12:31 pm
I've had a pair on the rear of the mini K for many years - no problems but don't drive fast enough to notice any real difference.
It is up to you. The Superfins are about 3 times the price of cast iron ones but look pretty.
Checked the width of the insert on a pair of Superfins. Comes to 38mm which is very close to the width of the front brake shoes before the friction material of the shoes run over the alloy parts of the drum. Don't really know whether that will be a problem.
The cast iron drums are a fair bit wider at 48mm.
