It is currently Sat Jul 19, 2025 3:04 am
 Post subject: Guard removal
PostPosted: Sat Oct 01, 2016 10:18 pm
I'm in the process of removing the left hand guard on my 72 clubman .
Removing to repair inner panel due to hit in off centre left front so guard is repairable so want to save it.
Any hints or tips would be greatly appreciated .
Thank in advance Neil .
 Post subject: Re: Guard removal
PostPosted: Sat Oct 01, 2016 11:54 pm
drill out the spot welds...?
PostPosted: Sun Oct 02, 2016 7:52 am
Beer... Lots of beer
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
PostPosted: Sun Oct 02, 2016 7:59 am
I have a Sykes-Pickavent spot weld remover which does a great job. A pilot drill goes through the centre of the spot weld and then a cutter removes the welded piece.
PostPosted: Sun Oct 02, 2016 12:13 pm
I grind down a suitably sized drill bit so it's almost flat. Lots of patience. Sore wrists.
PostPosted: Sun Oct 02, 2016 3:20 pm
Simonw beer did not help but have decided patience is the go and in no great hurry so will take some time .
PostPosted: Sun Oct 02, 2016 3:24 pm
DavidE have similar but having trouble getting square on to welds being so close to the edge .
PostPosted: Sun Oct 02, 2016 3:26 pm
Simon k is that what they are . LOL
PostPosted: Sun Oct 02, 2016 7:10 pm
I have bought used something similar ... Have a few sizes 6mm 8mm etc..
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Oct 03, 2016 6:09 pm
Try adapting an extension to it. I've seen it done before with spade bit extensions I believe.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Aug 25, 2017 7:03 pm
Ended up buying donor car and cut complete left front out .
PostPosted: Fri Aug 25, 2017 7:07 pm
I was about to mention putting an inner guard on as well. It's easier to join at rear near shock mount than drilling out a stack of spots.
PostPosted: Sun Sep 03, 2017 4:58 pm
Spent last two days stripping and cutting up donor car . Not a lot that's any good but getting what I can of it . Body badly rusted and twisted from a bad hit in right rear .
Users browsing this forum: Bing [Bot] and 103 guests
