1971 Mini K front end squeak https://ausmini.com/forums/viewtopic.php?f=2&t=95969 |
Page 1 of 2 |
Author: | JC69 [ Wed Aug 30, 2017 1:17 pm ] |
Post subject: | 1971 Mini K front end squeak |
Hello - just got my mini back together and I get a squeaking at very low speed when the car coasts in neutral at very low speed - no sounds when in gear???? Any ideas |
Author: | Bill B [ Sat Sep 02, 2017 9:51 am ] |
Post subject: | Re: 1971 Mini K front end squeak |
JC69 wrote: Hello - just got my mini back together and I get a squeaking at very low speed when the car coasts in neutral at very low speed - no sounds when in gear???? When you say noise goes away 'in gear', is that just in a gear or is it with drive being applied? Like radiator cowl rubbing on body. Is the noise in time with engine revs, wheel revolutions or with suspension movement - like a CV boot or clip rubbing or a dry suspension cup? |
Author: | simon k [ Sat Sep 02, 2017 12:49 pm ] |
engine off, clutch in, gear selected, squeak? |
Author: | JC69 [ Mon Sep 04, 2017 2:24 pm ] |
Thanks for those suggestions - car is currently back for a final wet polish I will check out those suggestion when I get it back. |
Author: | Lillee [ Tue Sep 05, 2017 1:15 pm ] |
Wheels scrubbing on guard or inner wheel arch on rear? |
Author: | JC69 [ Sat Sep 16, 2017 10:35 pm ] |
Thanks again Car back and I can confirm the noise disappears when the the gear is engagedand in drive . Definitely not wheels scrubbing on the bodywork and definetly from the front not the back ??? |
Author: | goodie [ Sun Sep 17, 2017 6:50 pm ] |
Is your car Auto or Manual? |
Author: | JC69 [ Sun Sep 17, 2017 7:48 pm ] |
Manual |
Author: | Phil 850 [ Sun Sep 17, 2017 8:38 pm ] |
Lucky bugger, I wish I ONLY had a front end squeak ![]() |
Author: | Bill B [ Mon Sep 18, 2017 10:54 am ] |
Again, is the squeak in time with the engine, wheel rotation, suspension movement or random? |
Author: | JC69 [ Mon Sep 18, 2017 1:32 pm ] |
Definetly in time with wheel rotation ! |
Author: | JC69 [ Mon Sep 18, 2017 8:06 pm ] |
Tightened up the hub nuts to the next hole for the split pin and problem solved Thanks for all the suggestions. |
Author: | Bill B [ Tue Sep 19, 2017 10:26 am ] |
So pleased you found the problem because that wasn't very high on my list of next suggestions. |
Author: | 9YaTaH [ Tue Sep 19, 2017 3:27 pm ] |
JC69 wrote: Tightened up the hub nuts to the next hole for the split pin and problem solved Thanks for all the suggestions. Good...I would also make sure the hub is packed correctly with the right grease...if it can squeal with one castellation backed off...it may have also overheated a bearing... |
Author: | Lillee [ Thu Sep 21, 2017 9:44 am ] |
9YaTaH wrote: JC69 wrote: Tightened up the hub nuts to the next hole for the split pin and problem solved Thanks for all the suggestions. Good...I would also make sure the hub is packed correctly with the right grease...if it can squeal with one castellation backed off...it may have also overheated a bearing... This |
