front subframe dimensions https://ausmini.com/forums/viewtopic.php?f=2&t=95963 |
Author: | Booley123 [ Mon Aug 28, 2017 7:44 pm ] |
Post subject: | front subframe dimensions |
hey all, I'm wanting to build a engine cradle frame that I can hot run on. currently have the steel however no measurements to make the frame. the dimension I need are ( inside the square ) FRONT TO BACK and BETWEEN the mounts. Please see the attached photo for reference. |
Author: | John Sneddon [ Tue Aug 29, 2017 3:42 pm ] |
Post subject: | Re: front subframe dimensions |
We recently ran my engine on the workshop floor simply by sitting the whole unit on a piece of rubber conveyor belt - worked very sucessfully |
Author: | Kennomini [ Wed Aug 30, 2017 7:02 pm ] |
They are a very stable engine to run sitting on the ground. Is their a reason you cant use a subframe with some legs mounted under it? Another option is I have made many 500x500mm frames with decent castor wheels under them for my engines. Very easy to move around the shed and decently stable. |
