It is currently Sat Jul 19, 2025 12:48 am
PostPosted: Mon Aug 28, 2017 7:44 pm
hey all,
I'm wanting to build a engine cradle frame that I can hot run on. currently have the steel however no measurements to make the frame.
the dimension I need are ( inside the square ) FRONT TO BACK and BETWEEN the mounts. Please see the attached photo for reference.
PostPosted: Tue Aug 29, 2017 3:42 pm
We recently ran my engine on the workshop floor simply by sitting the whole unit on a piece of rubber conveyor belt - worked very sucessfully
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Wed Aug 30, 2017 7:02 pm
They are a very stable engine to run sitting on the ground.
Is their a reason you cant use a subframe with some legs mounted under it?
Another option is I have made many 500x500mm frames with decent castor wheels under them for my engines. Very easy to move around the shed and decently stable.
