su twin carb manifold id https://ausmini.com/forums/viewtopic.php?f=2&t=95956 |
Author: | mark2man [ Sun Aug 27, 2017 7:40 pm ] |
Post subject: | su twin carb manifold id |
Could someone tell me if a su twin carb manifold stamped aeg573 p still classed the same as a mark 2 manifold aeg 573 or are they different. cheers |
Author: | gtogreen1969 [ Sun Aug 27, 2017 8:27 pm ] |
Post subject: | Re: su twin carb manifold id |
There are 4 AEG573 manifolds that I have seen. You would have to check with the rivet counters at show and shines but I think any manifold showing the AEG573 should be ok for a MK2S. The first casting was numbered AEG573 only and very roughly as well. The AEG573 was located at the front right. Attachment: Early AEG573 manifold.jpg The second was AEG573 P. The first of these used the early manifold and just added a P below it. Attachment: Early AEG573 P.jpg They then re-casted the manifold and the AEG573 P was moved up to the top of the manifold. Attachment: AEG573 P.jpg The fourth was actually used on the Clubman GT. It used the later casting but had the AEG573 ground off, the P remained and then the number 12G2463 was stamped into it upside down. Attachment: 12G2463 CLUBMAN GT AEG573 ground off and stamped 12G2463 upside down.jpg I don't have any documentation to back up my findings. Only what I have seen. |
Author: | winabbey [ Sun Aug 27, 2017 9:11 pm ] |
This may be of help - viewtopic.php?f=25&t=89247 |
Author: | mark2man [ Mon Aug 28, 2017 9:32 am ] |
thanks guys for that helpful info much appreciated cheers |
Author: | 1071 S [ Mon Aug 28, 2017 5:25 pm ] |
Then there are the Special Tuning items intended for 1 1/2 carbs.... Cheers, Ian |
