https://ausmini.com/forums/
tacho erratic
https://ausmini.com/forums/viewtopic.php?f=2&t=95913
Author:  miniblue [ Fri Aug 18, 2017 5:42 pm ]
Post subject:  tacho erratic
Have installed a new tachometer SAAS type electronic and the revs are anything from bouncing to double
Yes I have the thing wired correctly and switched to 4 cyl
Could the cheap electronic ignition be causing the problem or maybe the coil or leads ?
The car runs fine.
Any input would be appreciated
Author:  9YaTaH [ Sat Aug 19, 2017 8:26 am ]
Post subject:  Re: tacho erratic
yes...cheap electronic ignition...maybe.
If its easy, try going back to points to prove it or swap out the dissy for another :?: :D
PS could also be interference from copper type ignition leads...
