It is currently Sat Jul 19, 2025 7:18 am
 Post subject: not cool aircon
PostPosted: Thu Aug 03, 2017 2:51 pm
Hi guys, I have a 1989 mini 30 . it has aircon which does all the right things bar been cold. It blows , the revs drop when its turned on the compressor works the radiator sucks and there is liquid bubling through the canister window but it doent blow cool air. The lower blower levels are imtermitant but dosnt blow cool even when they are woking. Any ideas could it be electrical or just need a regas??
Thanks simon
 Post subject: Re: not cool aircon
PostPosted: Thu Aug 03, 2017 4:25 pm
regas would be my first guess without measuring anything
PostPosted: Thu Aug 03, 2017 6:11 pm
If it's low on gas it's leaking. Where's the leakage ?
Usually around the evaporator (under your dash) leaves commonly collect there via Air ducts and condensation rots them and the aluminium core. That's worse case.
Compressor could be tired
Check your joints for dirty connections. That's a sign of leaking as well
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
PostPosted: Thu Aug 03, 2017 6:57 pm
When I had low gas (in another make of car) they recharged with a fleuro coloured gas so they could see the leaks.
PostPosted: Fri Aug 04, 2017 7:13 am
+1
Sent from my Nexus 6P using Tapatalk
PostPosted: Fri Aug 04, 2017 8:13 am
First thing to do is get some pressure gauges on it! everything else is guessing. any A/C shop can help you.......................
PostPosted: Fri Aug 04, 2017 10:10 am
cheers guys will get it booked in next week.
PostPosted: Fri Aug 04, 2017 12:17 pm
+1
Simonw
Brisbane QLD
- 1969 Mini K
