It is currently Sat Jul 19, 2025 7:16 am
 Post subject: tough pulley nut
PostPosted: Fri Jul 28, 2017 1:54 pm
simple question...
before i start smashing things coz it's really starting to get on my nerves ... how does one get this freaking pulley nut off?
This thing will not budge.
 Post subject: Re: tough pulley nut
PostPosted: Fri Jul 28, 2017 2:50 pm
pulley nut on what?
PostPosted: Fri Jul 28, 2017 4:21 pm
A good penetrating oil for 24+ hours and a decent sized impact gun will pretty much do the trick on anything that can be undone!
PostPosted: Fri Jul 28, 2017 5:01 pm
Have released the bent over washer?
PostPosted: Fri Jul 28, 2017 5:43 pm
Yeah. Washer is out of the way. Will try some wd40. Or whatever I have.
It's the fan belt pulley nut. It holds on the pulley. Fan belt drives the fan, water pump, alternator..... I think that's all. There's only one pulley nut isn't there?
PostPosted: Fri Jul 28, 2017 5:52 pm
There is a crankshaft/harmonic ballancer pulley bolt or a generator/alternator pulley nut.
PostPosted: Fri Jul 28, 2017 6:13 pm
I think you are right. The water pump/fan pulley is held on by four small bolts so no big deal there. The crank pulley bolt is torqued up and can be difficult to budge.
Is the engine still in the car?
PostPosted: Fri Jul 28, 2017 6:23 pm
2 ways that work:
1. Remove starter, sit a bearing shell in the ring gear to lock crank then use socket and breaker bar to undo bolt. Or,
2. Sit breaker bar against firewall. Remove high tension lead from coil. Crank starter for a second or 2.
[edit] I am assuming this is for the crank pulley bolt.
Last edited by drmini in aust on Fri Jul 28, 2017 10:31 pm, edited 1 time in total.
PostPosted: Fri Jul 28, 2017 7:49 pm
simon k wrote:
pulley nut on what?
Got a pic of said pulley nut ?
PostPosted: Fri Jul 28, 2017 10:53 pm
yes.. the crankshaft /harmonic balancer pulley nut... it's 1 5/16. stubborn as a mule.
Engine is out of the car... and i don't have a spare bearing shell. but i will have soon. I've been using a big fat washer to jam the ring gear.
I think i'll just have to try harder. or get a longer bar. must put some wd40 on it or something... and borrow someone's air gun.
PostPosted: Sat Jul 29, 2017 7:36 am
You may find it's been loctited, try warming it with a hot air gun.
PostPosted: Sat Jul 29, 2017 11:49 am
I had that problem with a CV joint/hub nut recently on another make of car (never undone before in 32 years). Nothing would get it to budge. Impact guns wouldn't touch it, not even a 3/4 inch breaker bar with a long piece of exhaust pipe over the end. It snapped the head off a Sidchrome bar. In the end I got it off by heating it up with a MAP/PRO gas flame, that finally allowed it to be undone.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sat Jul 29, 2017 1:19 pm
Try smacking it (technical term) with big hammer, hit it inwards. Might jar thread into submission.
PostPosted: Sat Jul 29, 2017 3:01 pm
stop calling it a nut... maybe you're offending it, call it a bolt and it might come off
PostPosted: Sat Jul 29, 2017 4:01 pm
rattle that sucker straight off.
Users browsing this forum: Bing [Bot] and 80 guests
