It is currently Sat Jul 19, 2025 7:24 am
 Post subject: info for 1970 cs
PostPosted: Sat Jul 29, 2017 1:17 pm
1 master cylinders, I have been informed not to fit the small plate under the MCs is that correct.?
2 Looking for the colour code Jet Red anyone know ?
Thanks
 Post subject: Re: info for 1970 cs
PostPosted: Sat Jul 29, 2017 3:05 pm
should only be the plate with the bent up edge and tab for the engine steady
PostPosted: Sat Jul 29, 2017 6:59 pm
This should help ,
http://www.elevenhundred.com/colours.php
PostPosted: Sat Jul 29, 2017 7:19 pm
Gasket?
PostPosted: Sat Jul 29, 2017 8:27 pm
The plates were spacers for if the pedals didn't line up right, some had them, most didn't.
PostPosted: Sun Jul 30, 2017 8:04 pm
A bit more info.
As far as I know the extra plates were originally fitted to ensure the master cylinder piston cups weren't covering the compensating port on cars fitted with plastic tank master cylinders. The plastic tank master cylinders use a different pushrod assembly to the original metal tank master cylinders.
I don't know if it only applies to Girlock/Lockheed, PBR or both makes of plastic tank master cylinders.
It lifted the whole master cylinder up a few mms. I don't remember how thick the extra plate was.
According to Link it was common practice to remove the plate on the clutch master cylinder to get sufficient clutch travel.
If you do remove the plates you need to ensure the master cylinder compensating ports are not covered particularly for the brake.
Hope this helps.
RonR
68 build Mk1 Cooper S
Users browsing this forum: No registered users and 67 guests
