It is currently Sat Jul 19, 2025 4:49 pm
 Post subject: mini van fuel tank
PostPosted: Wed Jul 19, 2017 6:29 pm
Hi does a mini van have a special pipe from the tank to the electric fuel pump. My buddys van has just been put back together after mini years and arrived as a kit set. Pump works if we use a jerry can. New to vans ta Kiwinwgtn
 Post subject: Re: mini van fuel tank
PostPosted: Wed Jul 19, 2017 6:41 pm
Not 100% sure what you mean but it sounds like pipe is blocked. Can you blow through pipe into tank.
PostPosted: Wed Jul 19, 2017 6:52 pm
It looks like the fitting that goes into the tank has a long leader that goes into the tank. Looks like someone has done a dodey repair. You can blow compressed air through all pipes and tank easly. Nothing is blocked and all pipes etc are new except the tank.
PostPosted: Wed Jul 19, 2017 9:54 pm
You are talking about the tank breather maybe? It is a thin pipe connected to the filler neck. On late vans this goes to the charcoal canister up front.
