https://ausmini.com/forums/
mini van fuel tank
https://ausmini.com/forums/viewtopic.php?f=2&t=95767
Author:  kiwiinwgtn [ Wed Jul 19, 2017 6:29 pm ]
Post subject:  mini van fuel tank
Hi does a mini van have a special pipe from the tank to the electric fuel pump. My buddys van has just been put back together after mini years and arrived as a kit set. Pump works if we use a jerry can. New to vans ta Kiwinwgtn
Author:  peterb [ Wed Jul 19, 2017 6:41 pm ]
Post subject:  Re: mini van fuel tank
Not 100% sure what you mean but it sounds like pipe is blocked. Can you blow through pipe into tank.
Author:  kiwiinwgtn [ Wed Jul 19, 2017 6:52 pm ]
It looks like the fitting that goes into the tank has a long leader that goes into the tank. Looks like someone has done a dodey repair. You can blow compressed air through all pipes and tank easly. Nothing is blocked and all pipes etc are new except the tank.
Author:  drmini in aust [ Wed Jul 19, 2017 9:54 pm ]
You are talking about the tank breather maybe? It is a thin pipe connected to the filler neck. On late vans this goes to the charcoal canister up front.
