It is currently Sat Jul 19, 2025 4:47 pm
 Post subject: Fuel filter questions
PostPosted: Sun Jul 16, 2017 7:20 pm
Hi all
The clubby has a fuel filter just before the carby but I want to put another one just after the fuel tank. Will having two filters affect the flow of fuel and is it okay to put a fuel filter in the boot?
Thanks for any advice.
Eiles
PostPosted: Sun Jul 16, 2017 7:32 pm
Eiles, there should be no problem with flow unless you get tiny little filters. Shouldn't be a problem in the boot (so long as you ensure it has no leaks). A nicer place is to mount it outside of the car where tue fuel hose passes through the body.
PostPosted: Sun Jul 16, 2017 7:49 pm
I've see people putting two filters on, if crud or water gets in with fuel, it'll just block first filter,won't get to second
PostPosted: Sun Jul 16, 2017 8:48 pm
Crazy, I've seen another car with that exact same pump, filter and car stand.
PostPosted: Mon Jul 17, 2017 8:57 pm
Thanks guys. Much appreciated.
Eiles
