https://ausmini.com/forums/
Cooper S engine bay brake pipe routing
https://ausmini.com/forums/viewtopic.php?f=2&t=95650
Author:  8700s14 [ Tue Jun 27, 2017 10:05 pm ]
Post subject:  Cooper S engine bay brake pipe routing
I think I have my head around this, can someone please confirm if this sounds correct:
Master cyliner has a line running to the top of the booster
Front of booster has a line running to the top of the 3-way fitting mounted on the firewall
Bottom of the 3-way fitting goes to the brake line that runs to the rear
Left of the 3-way fitting goes to fitting that has the brake switch and front left/right lines
Also, am guessing it will be much easier to install clutch hydraulics first then brakes after?
Author:  drmini in aust [ Wed Jun 28, 2017 6:24 am ]
Post subject:  Re: Cooper S engine bay brake pipe routing
Yes all you said is correct.
Fitting clutch slave cylinder with booster in is a pita. Fit that first.
I find a crowsfoot socket useful for tightening the MC mounting nuts.
Author:  8700s14 [ Wed Jun 28, 2017 7:28 am ]
Thank you for confirming that for me doc
