It is currently Sat Jul 19, 2025 11:13 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
PostPosted: Fri Jun 16, 2017 4:04 pm
7.5" Cooper S Front Right:
Passenger side slid out perfectly, this drivers side one is giving me some grief!
Have removed the caliper, disc, tie rod and ball joints from the hub, but now trying to remove the hub from the axle it doesn't want to budge, any tips for how to get this off with basic tools?
Am guessing I may need to remove the driveshaft with the hub still attached and take the whole lot to hang in the vice so I can try to whack the end of the axle down and out of the hub?
PostPosted: Fri Jun 16, 2017 4:28 pm
I'd give the end of the CV a whack with a block of wood
PostPosted: Fri Jun 16, 2017 4:45 pm
As in, try to hit the threaded end of the axle toward the engine to set it free?
I did try this, but didn't want to go to crazy.
PostPosted: Fri Jun 16, 2017 8:33 pm
yeah, hold a block of wood on the threaded end (put the nut on a few turns) and then whack it
or pull the whole upright out with driveshaft... but it'll be the same, you need to give the CV a whack to release it
PostPosted: Fri Jun 16, 2017 8:41 pm
Is there much chance of damaging the cv doing this?
PostPosted: Fri Jun 16, 2017 8:47 pm
as long as you don't damage the thread... I doubt you'll abuse it much more than lugging a car around does... but they're cheap enough if you do hurt it
the conical split washer is out?
PostPosted: Fri Jun 16, 2017 8:51 pm
Yes, washer, drive flange and rotor are all off.
That is a fair point I guess, I might have another more enthusiastic go at it before taking the driveshaft out to try separating them on the bench. Not sure why, but the drivers side is giving me a lot more trouble than the passenger side, two of the screws that secure the drive flange to the rotor seem to be seized and the drive flange itself was very difficult to remove from the hub.
PostPosted: Fri Jun 16, 2017 9:28 pm
I had one like this recently. It had been parked for years and water got in. Hitting it didn't work so I took it to GR and he pressed it out. The CV was toasted.
PostPosted: Sat Jun 17, 2017 3:22 am
Have I got this right? you have the disc and drive flange off the hub and CV? but the shaft is seized in the hub? What it's seized on is the bearings, I think you will find that by the time you get the hub off, the bearings and CV are going to be toast. I'd get replacements in...............
But yes you can place a block of HARD wood not pine over the threads and hit it as hard as you like with a heavy hammer use a dead blow technique ie do not let the hammer bounce back drive it through.
PostPosted: Sat Jun 17, 2017 10:00 am
Could you apply a flame (such as MAP burner) to the hub?
PostPosted: Sat Jun 17, 2017 10:51 am
Correct.
I doubt it would help, the shaft would be fused to the bearing, I don't see that heating the hub would make much difference.
PostPosted: Sat Jun 17, 2017 12:03 pm
replace the bearings and cv, they're not very expensive. pull the driveshaft and hub from the car and whack the cv out from the front of the hub.
PostPosted: Sun Jun 18, 2017 1:06 pm
Another quick question, under normal circumstances, does the driveshaft just slide out of the inboard hardy spicer coupler or would you need to undo the 4 bolts and remove the coupler from the shaft with a press?
PostPosted: Sun Jun 18, 2017 1:12 pm
It will slide out
PostPosted: Sun Jun 18, 2017 1:17 pm
Goldbrocade_62 wrote:
It will slide out
Thought that should be the case, looks like I have a lot of problems with things fusing together on this side of the car!
