It is currently Sat Jul 19, 2025 11:19 pm
 Post subject: Su carb leak
PostPosted: Sun Jun 18, 2017 12:04 pm
Hi guys. Just had this happen car was running like crap and changed plugs rararar...
Noticed this is dripping fuel. Easy fix or carbs off job?
Cheers Brett Nosse
 Post subject: Re: Su carb leak
PostPosted: Sun Jun 18, 2017 12:14 pm
Thats the end of the throttle shaft, so it is flooding.
I would guess that the fload/needle has an issue. Pull the top off the float chamber and see if the float still floats, and if so, have a look at the needle and seat. It may just have a bit of crap in it.
Tim.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Sun Jun 18, 2017 1:18 pm
Thanks Tim! cleaned out some crud... Did it the otherday as well. , but must have got not all of it.. damn running my tank dry a few weeks back :-(
PostPosted: Sun Jun 18, 2017 2:00 pm
Put a filter in that fuel line!!
PostPosted: Sun Jun 18, 2017 2:17 pm
I have.. maybe time for a new one
PostPosted: Sun Jun 18, 2017 2:21 pm
If you have a filter in there and your getting chunks big enough to clog the valve, check the fuel lines, they may be breaking up on the inside and any hose after the filter is suspect.
PostPosted: Sun Jun 18, 2017 4:19 pm
Maybe fit a second filter in the engine bay before the carb.
Sent from my Nexus 5X using Tapatalk
Users browsing this forum: Astroblue, Majestic-12 [Bot] and 89 guests
