Morris 1100S https://ausmini.com/forums/viewtopic.php?f=2&t=95556 |
Page 1 of 3 |
Author: | zulu_warrior1976 [ Mon Jun 12, 2017 5:31 pm ] |
Post subject: | Morris 1100S |
Hi guys, Does anyone know if a Morris 1100s motor will fit in a mini? Zulu |
Author: | 1071 S [ Mon Jun 12, 2017 5:43 pm ] |
Post subject: | Re: Morris 1100S |
Yes..with a few minor changes including a change of diff... Cheers, Ian |
Author: | justfanginaround [ Mon Jun 12, 2017 6:24 pm ] |
trim the front engine plate { front engine mount in morrie 1100} check the diff ratio, std 1100 is 4.2ish {I think} the gearbox extension housing is different to a mini one, slightly longer and has a sandwich plate { not a tasty treat} between box and shift housing. stick a mini radiator and shroud on it and welcome to the big bore club. |
Author: | zulu_warrior1976 [ Tue Jun 13, 2017 1:24 pm ] |
silly question this... but how much do you need to trim off? |
Author: | drmini in aust [ Tue Jun 13, 2017 3:36 pm ] |
Cut the mount brackets off, or trim it to Mini shape. Use oxy or angle grinder. It's just for clearance. |
Author: | slide [ Tue Jun 13, 2017 6:19 pm ] |
If you keep the 1100S diff housing make sure you get the remote gear change linkage too from the 1100 as it bolts to the diff housing differently to a Mini one due to the rubber sandwich plate. I have this in my van and it works fine. |
Author: | drmini in aust [ Tue Jun 13, 2017 6:34 pm ] |
Re the rubber sandwich plate, you can burn the rubber out and weld a steel strip in between to make it solid. Like Mini remote feel then. |
Author: | zulu_warrior1976 [ Tue Jun 13, 2017 8:58 pm ] |
Such great info Dr Mini. What would the benefits be of the 1100 S motor over a mini 1275? |
Author: | drmini in aust [ Tue Jun 13, 2017 9:19 pm ] |
Morris 1100S motor is much the same as any other non S 1275. But note the gearbox is only 3 synchro, and parts are getting scarcer for these. Most people put the 1100S onto a Mini K remote box, or a rodchange one. Both are 4 synchro. |
Author: | simon k [ Tue Jun 13, 2017 9:54 pm ] |
zulu_warrior1976 wrote: Such great info Dr Mini. What would the benefits be of the 1100 S motor over a mini 1275? there is no difference, therefore no other benefit. They're cheap and easier to get cos there were a lot more of them made.... If you can buy one, buy it... I've had an 1100S motor in my cars since 1995 - I say cars because I've moved the same motor from car to car, and I say the same motor because it's the same crank, but I think I've had 4 different blocks |
Author: | 36 [ Wed Jun 14, 2017 2:35 pm ] |
No sideplates in an 1100S. One less place to leak! Also, are they only a 9 stud head not 11 stud? |
Author: | simon k [ Wed Jun 14, 2017 3:55 pm ] |
36 wrote: Also, are they only a 9 stud head not 11 stud? well, yeah, but only S motors had an 11 stud head standard, 1275LS, Californian Mokes, Rovers etc. had 9 stud heads but that doesn't matter one little bit, and it can easily be changed with a drill... |
Author: | zulu_warrior1976 [ Wed Jun 14, 2017 4:06 pm ] |
drmini in aust wrote: Morris 1100S motor is much the same as any other non S 1275. But note the gearbox is only 3 synchro, and parts are getting scarcer for these. Most people put the 1100S onto a Mini K remote box, or a rodchange one. Both are 4 synchro. I'm thinking it will go on a mini K with the manual rod changer box. |
Author: | Phil 850 [ Thu Jun 15, 2017 12:32 pm ] |
I have an 1100S on a 22G1128 (4 synchro) box. I changed the original 4.13:1 diff for a 2.95:1 and it is now an amazing highway cruising machine, but still has reasonable acceleration. |
Author: | zulu_warrior1976 [ Thu Jun 15, 2017 8:23 pm ] |
I love it Phil. Thanks! |
Page 1 of 3 | All times are UTC + 10 hours |
