https://ausmini.com/forums/
Please delete
https://ausmini.com/forums/viewtopic.php?f=2&t=95553
Author:  drmini in aust [ Mon Jun 12, 2017 3:43 pm ]
Post subject:  Re: Mini runs rich/stalls when idling
If the carb was rebuilt it may have a non genuine main jet and its hose. I had one on my 1412, one day I got a bad load of fuel from Caltex and it behaved as yours is. Barely made it home with the choke out. Investigation showed the fuel had swelled the hose shut. Replaced it with a genuine jet and all was good.
Author:  peterb [ Tue Jun 13, 2017 6:59 am ]
Probably is a fuel related problem but don't discount ignition altogether. A dud condenser can cause similar, makes spark weak. That's my 2c worth.
Author:  simon k [ Tue Jun 13, 2017 12:55 pm ]
if it's been sitting with the same fuel for more than a couple of months, dump it - easiest thing to rule out
You can put the old fuel in your daily driver - it'll just mix in with whatever's in there now
