Mk1 Cooper S Correct CV Shafts/Uni Joint? https://ausmini.com/forums/viewtopic.php?f=2&t=95539 |
Page 1 of 2 |
Author: | 8700s14 [ Fri Jun 09, 2017 10:53 am ] |
Post subject: | Mk1 Cooper S Correct CV Shafts/Uni Joint? |
What is the correct CV inner joint setup for the Mk1 Cooper S? My car looks like it has standard universal joints like: http://www.classicmotoring.net.au/cmos/ ... ts_id=1645 But then I read the description and it states "Except for Cooper S" |
Author: | minimans [ Fri Jun 09, 2017 11:18 am ] |
Post subject: | Re: Mk1 Cooper S Correct CV Shafts/Uni Joint? |
Hardy Spicer joints were an option on early Cooper S not Std fitment. Their were Cooper S specific doughnuts Originally but were superseded to one type. |
Author: | timmy201 [ Fri Jun 09, 2017 11:20 am ] |
The ones you linked are an aftermarket replacement for the original rubber cross joints. Original http://www.classicmotoring.net.au/cmos/ ... cts_id=107 |
Author: | 8700s14 [ Fri Jun 09, 2017 11:21 am ] |
minimans wrote: Hardy Spicer joints were an option on early Cooper S not Std fitment. Their were Cooper S specific doughnuts Originally but were superseded to one type. Thanks for the quick reply, that makes me feel a bit better, I was starting to think it was for sure meant to have the hardy spicer units and had been converted for what ever reason. A somewhat embarrassing question now... are the universal joints supposed to have a rubber boot to protect them? |
Author: | 8700s14 [ Fri Jun 09, 2017 11:23 am ] |
timmy201 wrote: The ones you linked are an aftermarket replacement for the original rubber cross joints. Original http://www.classicmotoring.net.au/cmos/ ... cts_id=107 Yes I realize that, but in the description for either it states "Except Cooper S" |
Author: | drmini in aust [ Fri Jun 09, 2017 12:00 pm ] |
I believe they went to Hardy Spicer in 1966. Std not optional. Shaft splines are the same so either fits. |
Author: | 1071 S [ Fri Jun 09, 2017 12:47 pm ] |
Early ..ie 63/64 etc Cooper Ss (UK built cars) had the "normal" Mini rubber cross type joint. The original link is for the aftermarket item that could be used as a direct replacement for the standard (i.e. factory) rubber joint. Later (don't know exact changeover point) - but I think including Aus built Ss used the metal Hardy Spicer joint.... and its associated fittings. The link is to an Australian company that doesn't seem to appreciate that their comment is not completely correct...but may be so for Aus built cars. Cheers, Ian |
Author: | gtogreen1969 [ Fri Jun 09, 2017 1:07 pm ] |
I have the changeover listed as engine 9FSAY 41234. But i dont know where that info came from. |
Author: | 8700s14 [ Fri Jun 09, 2017 1:30 pm ] |
Oh ![]() Should the rubber X style uni joints still have a boot to protect them? |
Author: | winabbey [ Fri Jun 09, 2017 3:00 pm ] |
8700s14 wrote: Oh ![]() Should the rubber X style uni joints still have a boot to protect them? I believe none of the uni joints ever had a protector boot, only the CV joint. I also thought all Australian assembled Cooper S had the Hardie Spicer joint, not the rubber uni, but happy to be corrected. In case it helps here's the relevant pages from the Mini parts catalogue PUB1012. Attachment: PUB1012 KA07-1 L.jpg Attachment: PUB1012 KA07-1 R.jpg Attachment: PUB1012 KA08 R.jpg
Author: | gtogreen1969 [ Fri Jun 09, 2017 3:35 pm ] |
This is where i got the 9FSAY 41234 changeover from. A few of the mini websites are also using the same info. Gearbox ID's http://mk1-performance-conversions.co.uk/gearboxes.pdf |
Author: | drmini in aust [ Fri Jun 09, 2017 3:44 pm ] |
I wonder what Uni joints the S ran at Bathurst in '66? |
Author: | 8700s14 [ Fri Jun 09, 2017 3:57 pm ] |
I asked the previous owner of my car (he bought it new) and he says it has not been changed, that's how he got it new (with the rubber joint). Wonder what the story is with my car (46388)? |
Author: | gtogreen1969 [ Fri Jun 09, 2017 4:10 pm ] |
8700s14 wrote: I asked the previous owner of my car (he bought it new) and he says it has not been changed, that's how he got it new (with the rubber joint). Wonder what the story is with my car (46388)? It does seem very late to have rubber unis. I think you would be hard pressed to find another 1967 car with rubber unis. |
Author: | miniron [ Fri Jun 09, 2017 10:59 pm ] |
My first S, registered in July 66 - car YKG2S2 1090 - engine No 9FSaY 39922, had the rubber inner unis and I had to replace the LH one several times over the 60K+kms that I had the car. It was a real PIA job to replace it without splitting the front suspension ball joints and removing the drive shaft. These also had the small vertical oil cooler and, IIRC, blue coloured displacers. I'm not sure but I think the 66 Bathurst cars used the Hardy Spicer inner unis and the large horizontal oil cooler. RonR |
