I would like to confirm that the wire going to the Oil filter switch was actually attached by the factory and if it exits the loom with the Generator Wires.
If anyone with a late MK1S could have a quick look for me I would be much obliged.
I don't want to cut away at my wiring loom too much.
Thanks
Here is the wiring diagram. It says White/purple.
The back of my speedo matches the wiring diagram. It has the wires to the passenger side orange globe disconnected and the driver side orange globe connected with a (White 12v supply) and (White/Purple or White/Brown to the switch).
