Hydro pipe restoration https://ausmini.com/forums/viewtopic.php?f=2&t=95485 |
Author: | mattywood [ Tue May 30, 2017 8:28 am ] |
Post subject: | Hydro pipe restoration |
I need some advice on some intact hydro pipes I have for my deluxe. What was the original finish on the pipes? Were the pipes painted and if so what colour. Also do all of the models that ran hydro have interchangeable pipes? |
Author: | drmini in aust [ Tue May 30, 2017 9:15 am ] |
Post subject: | Re: Hydro pipe restoration |
Pipes were not painted. There are 2 pipe types, 1965-67, and 1967-73? The latter run through channels pressed in the floor. Early type are clipped under floor. |
Author: | mattywood [ Tue May 30, 2017 10:23 am ] |
Thanks Doc. So just lightly sand with 1200 grit wet and dry and we are good? |
Author: | Flute [ Tue May 30, 2017 10:50 am ] |
More info that may be helpful. I'm about to do mine too. viewtopic.php?f=2&t=94462 |
Author: | DavidE [ Tue May 30, 2017 11:10 am ] |
mattywood wrote: Thanks Doc. So just lightly sand with 1200 grit wet and dry and we are good? Or fine steel wool (without added soap). |
Author: | mattywood [ Tue May 30, 2017 11:42 am ] |
Flute wrote: Thanks for that. I've been reading the info about the hydrolasticity and cleaning the bags out and storing them before I use them. How did you clean your hydro bags? |
Author: | Flute [ Tue May 30, 2017 3:28 pm ] |
I flushed them about 6 times with the hose and an air hose and stuff was still coming out. Eventually it got better and then I filled them with radiator fluid and stuck a rubber cork from Clarke Rubber in the top and then repainted them. Having read this and the other newer threads I might do it again before they go back in the car. Here is the link to previous post and it shows the gunk that came out of my hydro bags. viewtopic.php?f=2&t=84897&start=15 |
Author: | mattywood [ Tue May 30, 2017 6:42 pm ] |
My gunk was the same colour and consistency but I didn't think to rinse mine. I only drained them. I will remove mine and do the same and rinse then add the coolant. The other thing I did with mine was apply phosphoric acid on the inside of the bag edge where the pipe exits to stop the rust then sprayed that. |
Author: | p7676 [ Tue May 30, 2017 7:06 pm ] |
I have just made new hydro pipes same material and size as original, Bundy tube, otherwise it is hard to clean the old pipes. |
Author: | mattywood [ Tue May 30, 2017 7:55 pm ] |
Did you use the original fittings on the new tube? |
Author: | p7676 [ Mon Jun 05, 2017 7:29 pm ] |
used all original fittings, double flare on tubes P7676 |
