https://ausmini.com/forums/
Twin SU air cleaner securing studs
https://ausmini.com/forums/viewtopic.php?f=2&t=95460
Author:  Stibbsy [ Fri May 26, 2017 7:07 pm ]
Post subject:  Twin SU air cleaner securing studs
Do the studs that the wing nuts screw on to to secure the air cleaner box screw into the air throat elbow. Some butcher has done a mod way back, as the air box was secured by nuts.
Can new studs be purchased with the wing nuts?
Author:  carbon [ Sat May 27, 2017 5:06 am ]
Post subject:  Re: Twin SU air cleaner securing studs
I think the elbow studs may be cast in, no sign of threading at lower end and also they are not quite straight. The ones I have seen have slight kink in the stud, possibly to get it lined up with air filter top plate holes.
Author:  gtogreen1969 [ Sat May 27, 2017 2:06 pm ]
I once tried to unscrew the stud as i was going to design a more free flowing elbow using a different way of attaching the airbox. I put the exposed long stud into a vise and tried unscrewing it. It would not budge. Hitting the elbow with a soft mallet still would not budge it. I gave up on my idea.
Author:  Stibbsy [ Sat May 27, 2017 4:25 pm ]
Thanks. They have been extended, so I should be able to get them back to take the correct wing nut setup.
