It is currently Sat Jul 19, 2025 11:20 pm
 Post subject: Electrical Issues
PostPosted: Thu May 25, 2017 5:22 pm
So I decided to take the mini to get some bits before Hay, and on the way, the engine cut out while driving.
I jiggled some wires, checked some connections, verified the fuel pump was working and nothing. Engine would crank but wouldn't fire.
After about 15 minutes or so, it started up, no problems. Then it died about 2 minutes later. Another 15 minutes and it started again, only to die while I was putting the grill back on. Another 15 minutes or so, started up, and drove for 5 minutes or so before it died. Another wait and it started again and I made it home.
I noticed that when it dies, my wipers don't work, and neither do my indicators. Based on this, I'm assuming some kind of earthing issue perhaps?
Help!
Thanks,
Richard
 Post subject: Re: Electrical Issues
PostPosted: Thu May 25, 2017 5:48 pm
Could be a dirty fuse, if someone has put the ignition circuit on the wrong side of it. It's supposed to be unfused. But it did happen, on my car once.
PostPosted: Thu May 25, 2017 5:55 pm
I pulled fuses out while it was running and it didn't cut out. And the indicators kept flashing.
I doubt my electrical system is particularly well implemented.
PostPosted: Thu May 25, 2017 8:18 pm
Could be as simple as a loose battery terminal - one that has not been done up properly.
PostPosted: Thu May 25, 2017 8:26 pm
I doubt the starter would crank in that case.
It's a connection which affects the dizzy, wipers and blinkers, but not the starter.
PostPosted: Thu May 25, 2017 9:35 pm
Ignition switch
PostPosted: Thu May 25, 2017 9:55 pm
gtogreen1969 wrote:
Ignition switch
That is a possibility, I'll check it. Cheers.
PostPosted: Fri May 26, 2017 9:43 am
Could be clogged fuel filter or inefficient fuel pump and its running dry , waiting for 15 min allows it to refill and run for a short time before running dry again. Electrical situation may be linked somehow or just a coincidence.
PostPosted: Fri May 26, 2017 12:11 pm
gtogreen1969 wrote:
Ignition switch
yep - Brad's on it - reckon wires on the back of the ignition switch are loose
PostPosted: Sat May 27, 2017 5:53 am
Dirty earth on the solenoide. The mounting plate is the earth. Either it will be mounted to the body or engine check for any sign of corrosion
Sent from my GT-I9505 using Tapatalk
PostPosted: Tue May 30, 2017 4:45 pm
gtogreen1969 wrote:
Ignition switch
It was indeed the ignition switch. Fixed in less than 5 minutes.
Now the temperature gauge isn't working... sigh.
PostPosted: Tue May 30, 2017 4:47 pm
redfive wrote:
gtogreen1969 wrote:
Ignition switch
Winner winner chicken dinner
PostPosted: Wed May 31, 2017 5:34 pm
What do you need one of those for?
Mokes & De Luxes never had 'em. :P
Users browsing this forum: Astroblue, Majestic-12 [Bot] and 97 guests
