Master cylinder rebuild https://ausmini.com/forums/viewtopic.php?f=2&t=95441 |
Author: | 8700s14 [ Mon May 22, 2017 10:10 pm ] |
Post subject: | Master cylinder rebuild |
Hey all, just chasing opinions on a bit of pitting in a master cylinder. I gave it a quick hone and the only bit of corrosion that didn't come out is as pictured. I can't feel it when I rub my finger on it, but just don't know if I should proceed with a rebuild or should expect it would be doomed for failure? |
Author: | 1071 S [ Mon May 22, 2017 10:41 pm ] |
Post subject: | Re: Master cylinder rebuild |
The worst that can happen is that you may find it leaks a bit once you get it back together... it won't suddenly fail. If you can't face doing it twice then get a new one. Otherwise give it a go... if you can't feel any roughness then I would be optimistic. Cheers, Ian |
Author: | gtogreen1969 [ Mon May 22, 2017 10:49 pm ] |
The first seal starts a long way down the bore. Just measure the depth from the circlip groove to the seal. |
Author: | cooperess [ Tue May 23, 2017 11:13 am ] |
You could also get iy resleeved in stainless steel ![]() |
