unusual wear on clutch https://ausmini.com/forums/viewtopic.php?f=2&t=95417 |
Author: | peterb [ Fri May 19, 2017 6:35 am ] |
Post subject: | Re: unusual wear on clutch |
Looks like slipping / excessive hard starts to me. |
Author: | simon k [ Fri May 19, 2017 9:50 am ] |
engine mounts not stiff enough? ask on a honda forum, maybe it's a normal thing |
Author: | MiniBrad [ Sat May 20, 2017 11:29 am ] |
My initial thought was clutch cover not installed evenly because of how the hot spots on the flywheel are but there other things that can give those symptoms too. Maybe while it's out assemble it while it's on the bench & see how the diaphragm fingers sit & if they are worn unevenly & have a look at the throw out bearing too for wear etc. Now is the easiest time to replace it ![]() In the 3 years that you have had it, how many klm do you think you have travelled? Brad |
Author: | monda [ Sat May 20, 2017 12:25 pm ] |
Cheers for the feedback Not many hard starts and I didn't slip it too often. Engine mounts are rock solid, I have posted on 16vminiclub too Bugger all kms - 2K/3K |
