Mk1 S oil cooler https://ausmini.com/forums/viewtopic.php?f=2&t=95393 |
Author: | Tomtax [ Sun May 14, 2017 5:31 pm ] |
Post subject: | Mk1 S oil cooler |
Does anyone know when oil coolers went from being engine mounted to behind the grille? Did the engine mounted oil coolers result in no angled reinforcing bracket or was there still a vertical bracket or maybe no bracket at all Thanks all |
Author: | Bubbacluby [ Sun May 14, 2017 6:12 pm ] |
Post subject: | Re: Mk1 S oil cooler |
66 sometime. Not sure exactly.. Mine is April 66 and has vertical oil cooler type. It has vertical brace at the front rather than slanted and no flattened front valance. Also has no tabs in the boot, but just holes. Sent from my SM-G935F using Tapatalk |
Author: | miniresto [ Sun May 14, 2017 6:59 pm ] |
First car with oil cooler behind grille is believed to be car number 1344 and was an Aug/Sept 66 build. |
Author: | Tomtax [ Sun May 14, 2017 9:57 pm ] |
Thanks mini resto Can't get any better than a car number! Vertical brace? |
Author: | irossiter [ Mon May 15, 2017 7:58 am ] |
Mine is Oct 66 and usual behind the grille position Sent from my iPhone using Tapatalk |
